Can this computer be used to Autodesk Revit?
11 ANTWORTEN 11
Nachricht 1 von 12
1567 Aufrufe, 11 Antworten
Hello!
I am currently looking for a new computer for my education. I have found one, but I do not know if it fits the requirements. It should suit the requirements of "large complex models". I have found this one:
https://www.komplett.dk/product/927233/gaming/gaming-pc/baerbar/asus-zenbook-ux550ve-156-fhd-mat#
ASUS ZenBook UX550VE 15.6" FHD mat GeForce GTX1050Ti, Core i7-7700HQ, 16GB RAM, 512GB SSD, Windows 10 Home
Can someone perhaps tell me if this computer can run the program without problems? That would be great, thanks. Yes i have read the requirements, but sadly i dont understand, im not that technical. :leicht_lächelndes_Gesicht:
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: Anonymous
It is good to go.
Nachricht 3 von 12
dzanta
computer will run revit...however, graphics card is not the right type for autodesk software....go here to get a list...
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112&
i would go with windows 10 pro instead of home for work purposes
other than that...the system is fine.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Nachricht 4 von 12
als Antwort auf: dzanta
GTX 1050 video card is fine for a laptop for school work.
Nachricht 5 von 12
Viveka_CD
Hi @Anonymous
Welcome to the Autodesk community!
Please see similar thread HERE
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
Nachricht 6 von 12
Thank you for your answers! :leicht_lächelndes_Gesicht:
What about this one then? Is it better, or?
https://www.dustin.dk/product/5010897255/zenbook-pro-ux501vw
Nachricht 7 von 12
dzanta
i have a laptop with practically identical specs and it runs revit.  However, the gaming card isn't sanctioned to run revit properly and you will get issues such as ghosting images, materials not displaying properly, etc.
try to pick a machine that has a gold shield certified card from autodesk compatibility site...using there specific drivers.
Nachricht 8 von 12
David_Knight
My understanding is that the biggest difference between a geforce card and a quadro card is the memory type.  And that in almost every situation a geforce is a better buy.  This video was one i found particularly helpful.
Nachricht 9 von 12
dzanta
als Antwort auf: David_Knight
if you are tight on money (most students are)...go with gtx cards
if you have lots of dough....go with quadro cards
here is a link I found that explains the differences....
http://www.velocitymicro.com/blog/geforce-vs-quadro-whats-the-difference/
Nachricht 10 von 12
Viveka_CD
Nachricht 11 von 12
If I were you @Anonymous I would not waste money buying a laptop with Quadro video card.  I wouldn't even buy it for work, let alone for school.  Invest your money elsewhere wisely.
Nachricht 12 von 12
dzanta
als Antwort auf: ToanDN
if you cannot buy a desktop or laptop for school because the funds are not available or other reasons, perhaps the school you are attending has a computer facility center you can access to use their machines...
when i was in college, i couldn't afford a computer so I went to the university computer center and borrowed their machines.
if you are buying a machine on a very tight budget, I would look at a used, re-certified computer perhaps from DELL or HP outlet.
if you don't have to be mobile while using the computer, a desktop purchase is better and you can put any graphics card you want in there as well as swap out to a different card when needed
i have a dell precision m6800 with a quadro 5100m card in it for work and it works fine....no problems (approx. $3,500.00)
i have a dell xps 15 with a gtx 960m card in it for personal/remote work and it works fine other than the issues previously mentioned (approx. $1,500.00)
work within your budget and constraints and you will find something that works....good luck.
