revit entourage familes
Respected sir /Madam,
                        i saw a lot of websites and you tube also but not found .please will we posted   the   entourage type families video in youtube or any revit community website .  entourage family means cars ,trees, humans ,some type of rcp families etc.
Corsten.Au
Extract from apps.autodesk.com
Hope this will help you.
FREE ArchVision RPC Entourage Starter Pack
Win32 and 64, English
2018 now supported! Download and Drag & Drop RPC Content into Autodesk® AutoCAD®, Autodesk® Revit® & Autodesk® 3ds Max®. Place, edit & render thousands of RPC People, Trees, Cars & Objects.
https://apps.autodesk.com/RVT/en/Detail/HelpDoc?appId=4500868201744478807&appLang=en&os=Win32_64
http://labs.archvision.com/
https://www.youtube.com/watch?v=Eae3pcl4028
Cheers!
Corsten
Building Designer
Hello ganesh,
I've been looking for new entourage families and how to create them, which is why I'm here.  I still cannot make this work.  Do you have any videos or info. as to how to make entourage in Revit, I cannot.  I thought this would be as easy as it says but I cannot figure it out....
JLeibold
Sahay_R
In elevation views - I would prefer to use Detail Components for entourage.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
constantin.stroescu
you can make your own Entourage Family if you have a 3d dwg model and blueprints of an object.
That could be the case of cars. You can easy find .dwg blueprints of different car types. You can import these blueprints separately ( top, side , front and back) into your Entourage Family and control the visibility so to appear only in selected views . There will be no 3d , only a bunch of 2 d views that will appear on the same position in plan , elevations and section views. But if you find a 3 d model , you can import it to and place in the same position and make it visible only for 3 d views...
Constantin Stroescu
