Revit DWG Export default Version
Message 1 of 8
When exporting to dwg file, is there a way change the default version of the dwg to another version of autocad, instead of the latest verison?
Replies (7)
Message 2 of 8
Have you checked file type dropdown when you save your file?
Message 3 of 8
yes, but this always defaults back to the latest version when I reopen
Message 4 of 8
Modify the Export to DWG settings and save the Setup.  Such as 2013 Export.
Message 5 of 8
will this save as an 'Export Setup' option for all projects I open or just the one that I save the new export to?
Message 6 of 8
No luck, I created a new export and called it "2013 DWG EXPORT" but when I opened up a different project, it wasnt an option. So, is there a way to change the default "in session export set up" otherwise, I have to set this up each time I begin a new project Woman Sad
Message 7 of 8
You will need to add it to your template for it to be there at the start....it is project specific.
I'm searching now to see if you can add the information to the revit.ini
Message 8 of 8
any luck?
