How to move cursor othographically?
Message 1 of 25
How can I set the cursor so that it move orthographically?
I'm used to AutoCAD's looking so neat with all of the arrows from notes looking nice and parallel.
In Revit, the lines are always at some angle other than 0 or 90 degrees.
Any help out there?
Thanks -KLYPH
Replies (24)
Message 2 of 25
safakgunes
You mean like snaps configurations?
Message 3 of 25
Sahay_R
In order to stack notes and text - create the text and move it around - you will see guidelines pop up showing you when the text lines up.
Normally Revit is pretty good about drawing in Ortho mode. Try holding down the Shift key when you draw.
Or you could play with Snaps settings to find what you are comfortable working with.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 4 of 25
"Snap" in REVIT must mean something different that in AutoCAD.
I will check out "Snap" in HELP.
What I mean is that when I move the cursor right or left, the line is at 0-dregrees (or 180)
When I move the cursor up o down, the line is at 90-degrees (or 270).
Thanks for your quick reply -KLYPH
Message 5 of 25
What I want is when I have a series of notes, I want the arrows to be horizontal, and all parallel with each other.
It's easy in AutoCAD.
In REVIT, none of the arrows area at "0" degrees, so, they all look crocked.
I've looked at SNAPS, but it doesn't seem to apply to Note arrows.
Any help out there?
Message 6 of 25
Sahay_R
@Anonymous - for horizontal arrows - I would select the highlighted option while adding notes. This will give horizontal leaders with no angles
Rina Sahay
Message 7 of 25
No, using that merely connects the arrow head to the note. It also ends up a little crocked.
You must have some setting which makes you horizontal lines truly at 0 degrees.
I can't find anyway in REVIT.
I noticed that in SNAPS, it won't let me enter "0".
I'm lost -KLYPH
Message 8 of 25
aRcHiTeCt.JM
.... not the best solution
... but I have been drawing reference planes to get to that
..... at least is fast and easy....
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 9 of 25
RobDraw
As @Sahay_R mentioned. The guidelines are quite useful for this.
Rob
Message 10 of 25
Wait, wait, I'm getting lost.
I even adjusted my SNAP, but, now, I'm so confused that I can't even remember where one goes to adjust my SNAPS. The pressure comes from this Project's Due Date is today.
Message 11 of 25
cbcarch
Manage Tab> Snaps
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 12 of 25
Thanks. I needed that help.
Message 13 of 25
@Anonymous: Are you talking about Angular Snap Increments?
Message 14 of 25
All I want is that when I draw an arrow for a note, that the arrow line be level. That when the arrow line runs from left to right, the ends of the arrow should have the same "Y". It's easy in AutoCAD. It seems that in REVIT, everyone doesn't mind that off level lines. It's not really something one should have to spend time researching, but, no one has found an easy answer, or even seem to care.
Message 15 of 25
...oops. Sorry @cbcarch. Didn't mean to step on your toes.  My bad.
Message 16 of 25
@Anonymous wrote:
 ...no one has found an easy answer, or even seem to care.
If I were a lesser man, I might take offense to that statement.  I'm sure you didn't mean it that way.  Right buddy?
Message 17 of 25
RobDraw
It is easy in Revit. If you are close to horizontal, Revit will snap to it, kind of like object snap tracking in AutoCAD. Revit doesn't show the tracking line though. Alternatively, you can get it to ortho after you draw it with a grip edit.
Rob
Message 18 of 25
This would seem to be the solution, BUT down in the "Angular Dimension snap increments", it will not accept a "0.00" degree angle, nor a "180.0" degree angle.
Message 19 of 25
Aren't those the defaults? Orthogonal.  X and Y.
Message 20 of 25
When I draw the arrow for a note, the line is level, BUT as soon as I click the end, it's no longer level.
In a series of notes, one arrow might rise to the right, the next goes slightly down, the next no one can predict.
It really looks sloppy.
I do not have this trouble with AutoCAD, but, I've only been using it since the 1980s.
The sensitivity of the mouse is probably the problem, but, how to fix it?
