After dragging a plan on a print sheet there is no label with its description. I chose the option with visible title in 'edit type' (after clicking on a plan), but it is without a scale.
Can somebody help me and tell, how the label with a name and a scale of a drawing can appear automaticly after placing it in a sheet?
Solved by ToanDN. Go to Solution.
So, you drag a view onto a sheet and there is no viewport with title created? Can you share a portion of the RVT model for us to see?
