Why does this post replace the scale?
Gelöst! Gehe zur Lösung
Gelöst von ahjorn. Gehe zur Lösung
the "As Indicated" text replaces the scale because there are more than one views placed on the same sheet with different scales. If the scale of each view was the same then that scale would be shown in the title block.
When you have multiple different view with different scale in a sheet, Revit will set "as indicate" to the sheet scale. It can be annoying when you add in keyplan which is 1:2000 and you want your scale value to read 1:100 and not reading the keyplan scale. Often users would create shared parameter for scale and manually enter the value to overcome this shortcoming.
As everyone's saying, you have multiple views with different scale.. sometimes even Legend / Call you placement would affect this as well.
