revit doesn't detect correctly the topografy from CAD, why?
Soytei
Soytei
I'm trying to create a easy toposurface from an import CAD but revit 2024 doesn't detect it correctly, any advice or help.
I imported just the necessary layers: Contorno, CV & CVD
I attached a copy of the CAD file if the problem could be there.
I think that it was much easier in revit 2015 than now.
thx in advance
vitorbortoncello
Do you mean inaccuracies like this? Yes, TopoSolids in Revit 2024 aren't as effective as TopoSurfaces were. My advice is to use Revit 2023 for more precise topography
  Related info:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Inaccurate-toposol...
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Soytei
Hello!,
Yes, toposolid is a disaster vitorbortoncello.
