Revit does not export correct wall opening to IFC
Johris
Johris
Hi!
We have a problem with wall opening from Revit to IFC. Any ideas or a bug? Maybe @angel_velez  know?
Revit 2020.
IFC 2x3 (Tried IFC4 as well, same result)
Using Revit IFC exporter 20.1.0.2
Attached is a sample file of our Revit model and IFC.
In Revit:
In IFC:
In Revit the opening is made by our Door-family. And it is a correct wall opening in our Revit model. But not when exported to IFC.
FWIW: No problems here.  You sure you are doing it right?  Seems pretty straight-forward.  I can't imagine what you did wrong.
Following….
Johris
I dont know, I guess:
https://autode.sk/3dAP4n9
Johris
Got help from the support. THe Door-portal family contained several wall openings. It was fine in Revit but not when export. So make sure Door-familys only contain one wall opening.
luisPDAN6
We are experiencing the same problem The door opening is correct in Revit (right image) but is not existing in the IFC (left side). I am attaching a Revit 2021 project with that door family, and the exported IFC.
I only see 1 opening cut in my family.
What is going on?
