Revit Dimensions
Revit Dimensions
302965
Revit Dimensions
302965
Hi everyone,
I have a problem that when I change my temporary dimension to permanent dimension, it changes its value. What should I do with this problem?
d.ahmed.LW
@302965 press UN or go to the Manage section and open the Project Units option. Check if the below setting for Lengths and see what is set for Rounding off. Hope this helps.
Thank you, but it didn't change anything. The problem is that it is only one dimension in the whole project, on the view it shows 1914,99mm and when you click on the dimension, you can see that the actual value of the dimension in the properties is 1915mm. Also when I place in all the dimensions through the whole building there is no 0,01 which would add up to the 0,99 and make it 0.
I even tried replacing the walls and everything but it keeps doing the same thing, may honestly be just a glitch.
Still, thank you for your help!
ennujozlagam
maybe this one help?
https://www.youtube.com/watch?v=DPScZHh4P3U
Ok, nevermind, your first response actually helped a lot. The problem wasn't in the overall project unit settings. It gave me idea to see the dimension in the view with 3 decimal places, and the 3rd decimal place was the one making the problem. All solved, thank you so much for your help!!
d.ahmed.LW
That is great. Please do mark the solution to close the topic. Have a good day.
