Revit Decal is showing up in the wrong position
rory.ohareM5MYU
Observer Observer
rory.ohareM5MYU
Observer
Observer
I'm trying to insert a decal on the screens in this elevation but for some reason, it keeps jumping up to the floor above instead of where I place it... I can't move the decal down manually as an error pops up saying the decal is no longer lying on the host.
Has anyone come across this before?
EATREVITPOOPCAD
That's because the decal is hosted on that wall (or element). Unfortunately, you can not change the host of the decal once placed. So you just have to place a new decal in the desired location. If you have a hard time placing it on the right surface, hide all of the elements that are in the way.
The definition of insanity is doing the same thing over and over again and expecting different results
