The curtain wall in Revit is an incredibly useful tool for quickly and accurately creating building facades. With it, users can develop detailed facades by incorporating elements like glass, metal panels, and other materials easily and effectively. Let's explore how this tool can be used to create curtain walls with perfect curves.
How It Works: In Revit, the curtain wall is a construction system composed of panels, mullions (vertical and horizontal profiles), and fixings. The panels can be configured to include glass, metal panels, opaque materials, etc.
How to efficiently generate a curved curtain wall?
Solved by vitorbortoncello. Go to Solution.
REVIT - Curved Curtain Wall
The curtain wall in Revit is an incredibly useful tool for creating building facades quickly and accurately. With it, users can develop detailed facades, incorporating elements such as glass, metal panels, and other materials easily and effectively. Let's explore how this tool can be used to create curtain walls with perfect curvatures.
How It Works: In Revit, the curtain wall is a building system composed of panels, mullions (vertical and horizontal profiles) and fixings. Panels can be configured to include glass, metal panels, opaque materials, etc.
To be able to efficiently generate a curved curtain wall, we can simply and with a few edits achieve the desired result:
SETTING UP THE BASIC WALL
SETTING UP THE CURTAIN WALL
The freedom to experiment with shapes and volumes offered by curves allows for a more creative expression of architecture.
The footer profile used in the tutorial is available for use.
