Revit create materials every time when I update dwg-link
2 REPLIES 2
abajenov
135 Views, 2 Replies
Ladies and gentlemen, I need your help. The title says for itself. Those materails represent autocad layers and I don't need them in revit. Our costumer requires unused materials to be deleted. Thank you in advance!
2 REPLIES 2
in reply to: abajenov
More info needed.
Are you talking about the Layer Name or Material?  Or both?
Also, want do you do to "update" the Linked DWG - and, are you saying that every time you do "update", Revit creates new/additional instance properties for the Link?
abajenov
in reply to: barthbradley
Thank you! Solved! I simply created new material and assigned it to all imported objects.
Forma Design Contest
Technology Administrators
