Revit crashes when I duplicate views
barraza.js
barraza.js
Even in a new template or an demo project from revit duplicating vies makes every copy a dependent one. If I trie to duplicate a dependent one it crashes!
I have already reinstalled 2 times the software and still crashes. I have Revit 2022 installed and it has no problems but my projects are now on 2023 versions and I´m stuck! please help!
Here is a video of what Im saying 😕
Test I run for the video:
I open new construction template > open a plan view and turn walls red > duplicate independent view and turn walls green on both views. If I duplicate a dependent one Revit crashes. It does this on any given file.. 😫
What method are you using to turn the walls red? I can't tell in that video.
I can't replicate.  Do you have the latest and greatest build?
barraza.js
Ok, my bad. The "VV" screen not showing. viewport property: walls sectcion cut parameter and a solid fill.
Any way.. it all started after a big crash (first I ever had con Revit 2023) now any new duplicate view comes out as dependent. And now I noticed any copy paste even of a model line trhouhgs error message. I already reinstalled 2 times. It seems its something to do with memory.
The same exact issue seems to have been reported by from Diego_Alm : https://forums.autodesk.com/t5/revit-architecture-forum/revit-2023-error-duplicating-views/m-p/11493...
