Hello Revit Doctors 🙂
I'm working with Revit 2023 since the release without problems, but yesterday after a fatal error trying to open a titleblock family, Revit doesn't duplicate the views as the normal way.
I used the Basic Sample Project to test, and this is what happen:
1- This is the project browser when we open the file (I took the 'site' view from the sheet because I have different results when duplicate a view in a sheet and a view without sheet:
2- Duplicating a view in a sheet, with the options 'Duplicate' and 'Duplicate with detailing' I get a new level (Level 3) and the view duplicated is called just Copy 1. This new view 'Level 3' is the old 'Level 1' and is out of the sheet, as you can see:
3- Duplicating a view not in a sheet, also with the 'Duplicate' and 'Duplicate with detailing' I get a new name Site is now 'Site1' and the new view is simple 'Copy1':
4- Both situations, in the view tabs, loose the original name, and the changes i made in a view are the same in the other, can't have independent visualisations.
5- If I duplicate a view as Dependent, in both cases, Revit shut down immediately. All the error happens with all kind of views, not only with plans.
6- Revit is updated with the lastest hotfixes, Windows (W10) and computer don't have been uopdated recently. I also tried to reinstall Revit, i took all the plugins out, and I'm still having the same issue. The old Revit versions I have installed are working perfectly.
7- Using DiRoots to duplicate views, I have the same problems.
I'm in a corner without solutions and I can't go back to other Revit versions. There are anyone with an easy solution? Or the best way is to format computer and install all again?
The only solution that works is doing View->Plan Views->Floor Plan.
Thanks 🙂
Update:
- Tried to duplicate views with Dynamo and the result is the same.
