Revit could not load ............\IntfIFC.dll
ArmanMargaryan
ArmanMargaryan
When installing, I see Revit could not load C:\Program Files\Autodesk\Revit 2024\IntfIFC.dll. The program will now be terminated.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
Yah, had the same error thrown two days ago. You won't like the solution.  Uninstall and reinstall (from autodesk.account.com portal. Not Access.)
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-Complete-a-...
Don't worry about the Registry. Do everything else above it.
ArmanMargaryan
Thanks, I tried but it didn't work. I had to reinstall windows
Arman Margaryan
Linkedin | Facebook
ksullivan
Update in service pack corrected this. No uninstall reinstallation needed. Revit 2024.3.1 Update
CDVandi
Community Visitor
Community Visitor
Thank you, saved me an uninstall.
ksullivan
Happy to help it always makes my heart sink when I see uninstall / reinstall as the answer to these titles so much lost time.
