Revit content installation problems
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Over the past year, there have been a number of posts related to Revit content installation problems. Previously, we identified problems with the Autodesk Design Academy and the Autodesk Education Master Suite that would cause this problem. These issues have been addressed and should no longer be an issue.
Recently, we identified another scenario in which this issue is reproducible with network deployments of both the Premium and Ultimate versions of Building Design Suite 2015 and 2016. Specifically, BDS 2015 or 2016 deployment images that include Revit and Revit Content Libraries but none of the products that include the Revit Core Engine (Navisworks Simulate, 3ds Max and Showcase in Premium and Navisworks Manage, 3ds Max, Showcase and Inventor in Ultimate) will fail to install Revit content files. This problem stems from two files, master.rvt.xml and master.xsd, that are missing from the Img\Content\Revit folder. This particular issue can be resolved by copying the missing files from the installation media (located under Content\Revit) to the Img\Content\Revit folder.
However, there are additional reports that are not covered by this scenario and I'm starting this new post to focus our troubleshooting efforts. For those individuals that have, or continue to, encountered this problem, it would be very helpful if you could answer each of the following questions:
- What is the operating system of the machine on which this problem occurs?
- Are there any other Autodesk products installed on this system? If so, which Autodesk products?
- Is Revit being installed from physical media (DVD or USB), web installer, download manager, or browser download? Also, are you installing Revit from an Autodesk suite and if so, which suite?
- Does a master.rvt.xml files exists in your <INSTALLATION_MEDIA>\Content\Revit folder? Please note that the three letter designation between master and xml is derived from the version of Revit you are installing. As an example, master.rst.xml would be the file name for Revit Structure installations.
- Which content packs are you selecting for installation? To answer this question, expand the Revit Content Libraries product entry on the Configure Installation page.
- During the Revit installation, did you receive a Windows Security Alert related to the Akamai NetSession Client? If so, did you select the Allow Access or Cancel option?
- Are you able to download the cab file from this link: http://revit.downloads.autodesk.com/download/2016RVT_RTM/Content/Revit/en/RVT-en-US- i/tmplt.cab?
Additionally, here are some suggestions that may help to ensure the successful installation of Revit content:
- Prior to running the Revit installer, install all available Windows updates.
- Use the Autodesk Download Manager to acquire the Revit installation media. This version of the Revit installer contains the Revit content files, which eliminates the need to download these files during the installation process.
- On the Configure Installation page, make sure the Revit Content Libraries product entry enabled. Also, expand the Revit Content Libraries product entry and make sure that at least one content pack is selected.
- Run the Revit installation again and if content is still not installed, gather and post the following log files from the Windows temp folder: Autodesk Revit Content Libraries 201X Install.log and cp_install.log.
Hopefully we can gather enough information to identify why many of you have encountered this problem and then produce a solution.
Tony Michniewicz
Autodesk Revit QA
Tony Michniewicz
Revit Software QA Analyst
