Revit Column family height changing
7 REPLIES 7
Message 1 of 8
brianwclayton1969
436 Views, 7 Replies
Good evening, I have a column that I added a steel plate to and created a family. Now I can't make the height adjustment through the Properties box or the Type properties box without going into the EDIT FAMILY tab.
I have set the reference plane and nothing is locked, this is free moving. I am using a Revit HSS column already created I added a plate and created a family, now I want to make it adjustable in height, I couldn't find the place to add an additional level so I added the Reference plane.
See attached Revit family, it's in version 23
7 REPLIES 7
Message 2 of 8
you can try this and see if helps?
Message 3 of 8
There's a documented workaround to do this.  See this video.  There are others on-line.
https://www.youtube.com/watch?v=pmWiQB-bZd8
Message 4 of 8
Ennujozlagam,
What did you do to make the column adjustable?
Message 5 of 8
You ought to use the Generic Model two level based.rft (Revit Family Template).
Message 6 of 8
first edit your column family and add dimensions as shown
second load into your rfa file and add dimensions  height
Message 7 of 8
How 'bout just using the OOTB HSS? It's fully parametric.
Message 8 of 8
Barth,
I used the family OOTB and changed a couple of things, it works.
Forma Design Contest
