Revit Colours Window Help
rpe_ryd
rpe_ryd
Seems very basic but i've never understood this, can anyone help explain to me how I add colours to the colour blocks that i've highlighted in green in the attached screenshot please? I've only ever been able to use the very first block that i've circled in red. A quick explanation or link to a tutorial on it would be appreciated, thank you.
rxi.gg
select a blank space, then select the color you want, then Add
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
rpe_ryd
Thank you, I wasn't selecting a blank space first so everytime I was adding it was just replacing the first block. How simple!
