Hello!
Is it possible to export the inbuilt PDF export settings? if so, how?
Hello!
not that I'm aware of.... There is no option or button in the PDF Export window to export the "settings" out. You can save custom settings within the file.
there is an option in the Transfer Project Standards to copy the "PDF Export Setup Settings". if you have a Named Setting saved in a file you should be able to use the Transfer Project Standard option to copy it into another file.
Howard Munsell
