Revit Chimes when Deleting Elements
Message 1 of 17
Hi!
I am working in my Revit project file and am constantly deleting and replacing furniture items and walls. Every time I delete an element, there is a loud chime that goes off. It is the same chime that goes off when a warning box pops up, but I was able to turn those off. The only way I can turn off the "deleting elements chime" is by muting my entire computer, but sometimes I share my screen on Zoom and need to hear people on the call. Does anyone know how to turn off the sound that occurs when deleting elements?
Thanks in advance!
Replies (16)
Message 2 of 17
Why is it chiming?  What's the error?
Message 3 of 17
Hi barthbradley,
It is chiming every time I delete an item. No error or warning message appears. If I place a couch, wall, or any other item but decide to delete it, it chimes. It is so strange!
Message 4 of 17
Well, there's a warning or error associated with the chime.  You don't see anything?  Did you have a dual monitor setup at one time?
If you did, the warning/error dialog box may be off screen.
Message 5 of 17
Message 6 of 17
Good to know. I have never had a dual monitor set up with this laptop, so I don't know where the error/warning box has disappeared to... do you know how to get it back? I just did some research and it tells me to go to Manage -> Inquiry -> Review Warnings but the Review Warnings button is greyed out. I appreciate all of your help.
Message 7 of 17
Thanks, ToadDN! Hopefully once I get my error/warning box to appear again, I can use this to turn off the chime.
Message 8 of 17
That's a good thing.  No Warnings. Pat yourself on the back.
Now, where the heck is the warning box that's associated with the chime? Got me.
Message 9 of 17
Now I'm manually causing an error (drawing a wall on top of an existing wall) and the error box appears, but NO CHIME! There is still a chime with every item I delete. I'm at a total loss 😞
Message 10 of 17
Also, I'm using Revit 2019 - Student Version. Not sure if that'll change anything for anyone helping me troubleshoot.
Message 11 of 17
You sure it isn't your phone?
Kidding.
Very weird.
Message 12 of 17
martijn_pater
Turn off your sound...
Message 13 of 17
RobDraw
Are you using the keyboard delete key or the Revit command? Does it still make a sound if you delete in an alternative method?
What kind of error could be happening? (Delete by itself does not make a sound.) Are these elements pinned?
Have you ever had a second monitor plugged in? If so, try connecting another one so you can see that error message.
Rob
Message 14 of 17
Turn off Windows system's "Exclamation" sound then.
Message 15 of 17
….or change your wav from Chimes to Electric Love. he, he.
Message 16 of 17
You're onto something here... I used the delete button in Revit and there was no chime. The chime only occurs when I delete something using my keyboard. I have turned off the sound from my computer settings and it fixed the issue. Thank you for your help!
Message 17 of 17
RobDraw
So, your keyboard has a feature to make a sound when the delete key is pressed. Check your keyboard settings.
Rob
