Revit changing orientation of views in plans
info
info
Good morning
in the plans I make, Revit keeps shifting the view angle of the various plan components,  causing them to be turned 90 degrees for example, even when saving them explicitly otherwise. Any ideas what could cause this behaviour? (Revit 2022)
Anton
RDAOU
@info
Some plugins do that ... Example if one has Viewports that have a given value for ‘Rotated on Sheet’ (any value other than 0) get automatically aligned by the crop box boundary causing something similar to that unexpected 90 degrees rotation
Check the settings of any plugins that has such a feature or simply disable all and check
info
Ok, I didn´t have any plugins active, but solved the problem by fixing the viewpoint, thanks!
