Change Unit In Single View
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
rawezh
1566 Aufrufe, 2 Antworten
Is there an option to change units in one view not entire the project? for example I use meter unit in the project, but for some details in some views in the same project I want to use centimeters or millimeters, thanks
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
mhiserZFHXS
als Antwort auf: rawezh
Probably shouldn't be on the idea board...
But just create a new dimension type like you would a new door or a new wall. Call it "detail dimension" or whatever you see fit, and change the unit format.
Nachricht 3 von 3
rawezh
als Antwort auf: mhiserZFHXS
Thanks. I appreciate It, that's what exactly I want, thanks again & again
