Revit Build and Version numbers
9 REPLIES 9
Message 1 of 10
jagostinho74
4485 Views, 9 Replies
jagostinho74
I have been compiling this table with Revit Build numbers and how they tie to Control Panel Version numbers but I have some missing.
I use it to liase with IT and check which pcs at the office are lacking the service updates.
Could anyone point to an autodesk table where I could complete this table?
Or contribute with the versions that are missing?
Thank you
Autodesk ProductService Pack DescriptionBuild NumberBuild Number (Control Panel)
Autodesk Navisworks Manage 2015Service Pack 2012.2.1147.53
Autodesk Navisworks Manage 2015Service Pack 2, Service Pack 3012.3.1157.50
Autodesk Navisworks Manage 2015unknown012.3.1147.50
Autodesk Navisworks Manage 2016Service Pack 3, SP3 HF1Sep 17 201513.3.1278.94
Autodesk Navisworks Manage 2016Service Pack 4, Service Pack 3, SP3 HF1, SP4 HF1Jan 26 201613.4.1294.05
Autodesk Revit 2014Update Release 320140709_2115(x64)0
Autodesk Revit 2015Update Release 10 R220151008_0715(x64)15.0.1203.0
Autodesk Revit 2015Update Release 11 R220151208_0715(x64)15.0.1225.0
Autodesk Revit 2015Update Release 12 R220160120_0715(x64)15.0.1238.0
Autodesk Revit 2015Update Release 13 R220160220_0715(x64)15.0.1243.0
Autodesk Revit 2015Update Release 320140606_1530(x64)15.0.207.0
Autodesk Revit 2015Update Release 4 (aka Release 2)20140905_0730(x64)15.0.1103.0
Autodesk Revit 2015Update Release 5 (non R2)20141119_1515(x64)15.0.310.0
Autodesk Revit 2015Update Release 5 R220141119_0715(x64)0
Autodesk Revit 2015Update Release 8 R220150511_0715(x64)15.0.1170.0
Autodesk Revit 2015Update Release 9 R220150704_0715(x64)15.0.1190.0
Autodesk Revit 2016First Customer Ship20150220_1215(x64)16.0.428.0
Autodesk Revit 2016Release 220151007_0715(x64)16.0.1063.0
Autodesk Revit 2016Service Pack 120150506_17150
Autodesk Revit 2016Service Pack 220150714_15150
Autodesk Revit 2016Update 1 for R220151209_0715(x64)16.0.1092.0
Autodesk Revit 2016Update 2 for R220160126_1600(x64)16.0.1108.0
Autodesk Revit 2016Update 3 for R220160217_1800(x64)16.0.1118.0
Assistant BIM/CAD Manager
Manchester, UK
Thank you
Manchester, UK
9 REPLIES 9
Message 2 of 10
David_W_Koch
in reply to: jagostinho74
David_W_Koch
For Revit, take a look at this Autodesk Knowledge Base article.
There does not appear to be an equivalent article for Navisworks.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
David Koch
Blog | LinkedIn
Message 3 of 10
jagostinho74
in reply to: David_W_Koch
jagostinho74
Thank you for this link. Will surely help filling out the info for Revit 2016.
Navisworks updates seem more complex that Revit. Maybe why they do not have such table.
I am still missing some of the updates Control Panel Version numbers for R2014 and R2015. Any ideas on how can I get that info.
Kind regards,
J
Manchester, UK
Kind regards,
J
Manchester, UK
Message 4 of 10
alan.quinn
alan.quinn
Here's a few that you can add to your list:
Revit 2014 - First Customer Ship - Build: 20130308_1515 - 13.03.08151
Revit 2015 - Update 1- Build: 20151007_1515 - 15.0.379.0
Hope this helps and thanks for posting.
Message 5 of 10
jagostinho74
in reply to: alan.quinn
jagostinho74
It does, thank you. Specially for the 2015.
Manchester, UK
Manchester, UK
Message 6 of 10
Giosue.Garita
My name is Giosuè. I am a Revit specialist from the Autodesk Support Team.
Please see the links below; they contain all Build and Revision numbers for Revit 2015 and 2016 respectively (check the last column on the right side😞
Revit 2015 Product Updates
Revit 2016 Product Updates
I remain available for further clarifications.
Cordiali saluti / Kind regards
Giosuè Garita
Autodesk, Inc.
Giosuè Garita
Autodesk, Inc.
Message 7 of 10
Giosue.Garita
I was wondering whether the links I provided in my previous post contained helpful information for you.
In case you need further help regarding the 2015 revision numbers, feel free to keep me posted, and I will be happy to continue researching on this.
Giosuè Garita
Dipartimento di Architettura
Autodesk Revit Support Team
Giosuè Garita
Autodesk, Inc.
Giosuè Garita
Giosuè Garita
Autodesk, Inc.
Message 8 of 10
in reply to: Giosue.Garita
That was exactly what I was looking for.  I had opened a ticket with autodesk and my the assigned tech was not useful at all.  Thank you for those links.
Message 9 of 10
Giosue.Garita
Giosue.Garita
Hi Moses,
Thank you for your response.
I am sorry to hear the assistance you received from the support ticket was not helpful, I guess they were not aware of these links.
However, I am very happy I was able to give you a hand with your research.
Don't hesitate to contact us back if you have further concerns, we are always happy to help.
Giosuè Garita
Autodesk, Inc.
Hi Moses,
Giosuè Garita
Autodesk, Inc.
Message 10 of 10
eric.stimmel
eric.stimmel
Here is a single list for all releases of Revit. It's what I find myself referring to for this information.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/H...
