Revit Break Dimension Lines
Message 1 of 19
I am looking to break the dimension line in Revit when multiple dimensions overlap. This is not the Witness Line, but the line above which the dimension rests. Any thoughts on how to do this? Is it a tool I am missing?
Replies (18)
Message 2 of 19
Tab until you can highlight the dimension string then press the delete button?  If that isn't it a picture would help.
Message 3 of 19
Do you mean something like the "Dimension Break" in AutoCAD.  Revit doesn't have something like this.  Use Masking Region as workaround.
Message 4 of 19
That's exactly what I'm requesting. You're right, Revit does not have the option. I will just hope for the future releases to have this.
Message 5 of 19
Actually, the idea has been fielded before, but never got much traction/support.  Personally, I avoid crossing extension lines. I'll do baseline to mitigate.  And if I do have to cross, I don't break the line.   I don't think I ever used the command in Autodesk either.
Message 6 of 19
ssimleness
 Why would Autodesk remove the option? It used to be available in 2016.
This happens often enough that it should not have been removed and the command should be reinstated.
Placing a mask is a work around. Although that's a nice way for the short term, but that should not be the answer.
The right thing to do is have a tool that works correctly according to the national cad standards.
Autodesk, please, bring the tool back.
Message 7 of 19
Remove?  Revit has never had this ability.  Nor is it an ANSI Y14 drafting standard.
Message 8 of 19
RussellHolzinger
Message 9 of 19
I've been using Revit since Moses wore shorts, and I don't recall any such function.  Now, AutoCAD does have this function.  DIMBREAK.
FWIW: Your link goes to an AutoCAD-Mechanical page.
Message 10 of 19
Message 11 of 19
RussellHolzinger
Good eye. My bad.
Message 12 of 19
ssimleness
Barth, thanks for correcting me on these things. i actually looked up the NCS. It says avoid crossing dimension lines, but you may when avoidable. News to me.
Message 13 of 19
RobDraw
It's a huge problem that what used to be common knowledge about best drafting practices is being lost to technology.
Rob
Message 14 of 19
jrdoyleR2A82
just use detail lines to make it look like a break
Message 15 of 19
ssimleness
adding lines sure seems like a work around to me
verses making the dimensions have the functionality. It's not a big ask.
Message 16 of 19
jrdoyleR2A82
@ssimleness i agree. just thought id make the suggestion since it had not been mentioned here yet. People may prefer that workaround over a masked region.
But yes, it is a workaround still unfortunately and somewhat time consuming. It seems like it would be simple enough to allow users to use the "Split" function on dim witness lines just like you can on detail lines. However, here we are with Revit 2022 and that is just too much to ask for lol
Message 17 of 19
willanderson911
Observer
Observer
Select the dimension line
  • hover the mouse over the number you would like to remove and break the line.
  • hit TAB to select the segment.
  • press delete.
Now the Dimension Line is broken into 2 parts.
Message 18 of 19
candererFFXRC
Community Visitor
Community Visitor
It's 2025, there is still no native function for this. I doubt they plan on it.
Message 19 of 19
ssimleness
Kids
