Message 1 of 11
03:13 AM
no backward compability higher version to lower version. lower version to higher version can. thanjs
I would just like to say that this is the single most stupid thing I have ever seen. That is all. Thank you and goodnight.
You must be new here.
It feels like I am on here a lot. Also, there is a sharp pain in the side of my head.
Hi @Anonymous
I see that you are a new visitor. Welcome to the Autodesk community! ![]()
Revit does not have an option to save to a prior version native RVT file. Please see Backwards compatibility of Revit with earlier releases of the software
Let me know if you have additional questions.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
You'll have to export an IFC from Revit 2018 and open the IFC in Revit 2017.
This means that you'll unfortunately loose the integrity of your original model,
especially since Revit doesn't play well with IFC files.
Alternatively you could switch over to Archicad and avoid this headache altogether.
Regards
H
@Seychellian wrote:
Lol. Says it all doesn't it?
Not at all. This is a user help forum. Both posts are useless to the OP's issue.
