Revit backward compatibility
Message 1 of 11
Is it possible to back save a 2018 Revit file to a 2017 version?
RM
Replies (10)
Message 2 of 11
dmarchant
Message 3 of 11
ennujozlagam
no backward compability higher version to lower version. lower version to higher version can. thanjs
Message 4 of 11
Seychellian
I would just like  to say that this is the single most stupid thing I have ever seen. That is all. Thank you and goodnight.
Message 5 of 11
RobDraw
You must be new here.
Rob
Message 6 of 11
Seychellian
It feels like I am on here a lot.  Also, there is a sharp pain in the side of my head.
Message 7 of 11
Viveka_CD
Hi @Anonymous
I see that you are a new visitor. Welcome to the Autodesk community! Smiley Happy
Revit does not have an option to save to a prior version native RVT file. Please see Backwards compatibility of Revit with earlier releases of the software
Let me know if you have additional questions.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you!
Message 8 of 11
Zeelrich
You'll have to export an IFC from Revit 2018 and open the IFC in Revit 2017.
This means that you'll unfortunately loose the integrity of your original model,
especially since Revit doesn't play well with IFC files.
Alternatively you could switch over to Archicad and avoid this headache altogether.
Regards
H
Message 9 of 11
Seychellian
Lol. Says it all doesn't it? 😄
Message 10 of 11
RobDraw
Not at all. This is a user help forum. Both posts are useless to the OP's issue.
Rob
Message 11 of 11
s.borello
No.
