Hi all,
Firstly, sorry if this is in the wrong section of the forum, I'm very new to using this platform. I'd like to spark more of a discussion than ask a question, because I know that as with any 3D modelling software, there is more than one answer... Please bear in mind that I am from a Solidworks background and am a mechanical engineer, which is no doubt skewing the way I'm thinking this should be done!
I am wondering; how should I physically model a steel fabrication as a family with it's own parameters, so that I may drop multiple instances into a project?
I am in the process of learning Revit and setting up my companies Families ect as the first and only user. One of the things I am eager to discover is the best way to create a steel frame as a parametric family. The first example I've been working on is a fabricated frame consisting of a few equal angles and PFCs ect. I've added a drawing I've created using AutoCAD for reference. Now I understand that Revit is not the perfect software to model details, though I am prepared to work around the limitations. I'm happy that I'll have to leave bolts and other details to 2D detail views in the project.
I have tried to create ref planes ect, set up parameters, add model lines, assign beams to model lines using the insert component tool. What I can't get my head around is how to properly constrain these components to my 'model lines'. When I flex my model the joints and constraints all break.
Ideally I'd like to be able to use the place component - steel beams tool as it brings with it lots of useful parameters that I can use to calculate beams masses and sectional properties. I'm also hoping I can bring this through to a schedule in the project to create a 'Bill of Materials'.
Does anyone have any suggestions? Any inputs would be gladly appreciated.
Jake
