Revit Area plan duplication
jfjacques
Message 1 of 15
jfjacques
Is it possible to duplicate an area+area boundaries from one area scheme to another. Doesn't seem to be, even in 2024.
Is there a plugin or a work around?
Replies (14)
Message 2 of 15
blank...
Copy - Paste aligned to current view works.
Message 3 of 15
jfjacques
it doesn't, read the question
Message 4 of 15
blank...
It does for me, just tried it, read the answer.
Message 5 of 15
Yep, I read your question the same way as @blank...  I too would say use Clipboard Copy/Paste Aligned to Same Place between Views to "duplicate" the annotative elements.
If this isn't what you mean by "duplicate", maybe you can expound on the question.  Help us to help you.
Message 6 of 15
Maybe you mean this?
Message 7 of 15
You cannot copy paste areas but you can copy paste area separation lines.  That get you half way there.
Message 8 of 15
jfjacques
I figured as much - I had to use a plugin in the past. Just not looking to pay for it, was hoping there was a workaround now.
It gets me a third of the way there: I also have to do the tags, color scheme etc... Not really acceptable for a 30 story building with few repeating floors to boot.
Thanks, and thanks again for that sweet schedule you sent my way last week.
Message 9 of 15
jfjacques
"from one area scheme to another" ...
Message 10 of 15
I don't know what anybody is talking about here. I can easily copy/paste to current view an Area Boundary - AND Area itself (including Tag!) - to different Level. Doing so creates a brand-spanking new Area/Number based on the "duplicated" Boundary/Area.  Where this workflow fails is when you Paste Aligned to Same Place. I misspoke in my above reply.
Message 11 of 15
blank...
Same here.
Same here, had a brain fa*t, not aligned to same place but Paste from clipboard, then just move it where you need it.
Message 12 of 15
We are talking about copy paste across area schemes, not from level to level within one scheme.  It was said in the first post.
Message 13 of 15
sterling_bradby2
Can't expect too much out of Autodesk, they're just a little startup company after all...
Message 14 of 15
gsucciXHCQR
Why is this marked as "Accepted solution?".
Just stating the issue has no solution is not a solution.
Message 15 of 15
RSomppi
People will often mark a post that states there is no way to do it, to help others who may be looking for a solution know that there isn't one or the close the discussion.
