Count of 0 in schedules
jfjacques
jfjacques
I am making an AREA schedule.
Is it possible to get a COUNT of 0 to show in an area schedule?  I want my columns of roomtypes to line up.
I've tried if(COUNT>0, COUNT, 0)...
What are you ultimately trying to achieve? Obviously, Count cannot be zero, but there may be another way to get to where you want to go.  Sounds like you are after a particular Schedule Format.  Can you post a Screenshot or two showing what you have and what you want?
jfjacques
This is what I'm looking for. I can do for areas by adding a dummy area. Doesn't work with counts. I can get the 0 to show with an if condition that switches a blank for a 0, the issue is that in this case, when there's no area, there's no other column forcing a blank item in the schedule.  I'm thinking I  could create another column with a count and then use the count-1 as my value to solve it, as long as I have dummy areas, but it's not worked so far.
jfjacques
nothing eh....
