Revit and MS Project
3 REPLIES 3
1149 Views, 3 Replies
Can Revit be used like MS Projects to track projects and manpower? has anyone developed a template in Revit to do this?
3 REPLIES 3
Not really. You can add in parameters to sheets and then do a series of
calculations as to time spent on sheet, percentage complete, etc. However,
the time spent would have to be entered manually. Revit is a CADD package,
not scheduling software.
wrote in message news:5065645@discussion.autodesk.com...
boikoartem
I have published my new course on Udemy:
Project Management in Revit with 4D Time and 5D Cost
This course “Project management in Revit”, will present how real-life Revit projects have used the Tool Dynamo - to calculate working hours and working costs and with the help of an example, I’d like to show you how you can use project management 4D Time  and 5D Cost  in Autodesk Revit.
We will take the volume parameter of the building elements otherwise Revit-Families – then we will translate these volume parameters into time and cost.
The resulting data you can use in a variety of other programs for the control of the timing and the cost of construction. The obtained data can also be exported in another process management software Microsoft Project or other planning tools – such - scoro, asana, smartsheet, monday, hive, ganttpro or others.
RobDraw
in reply to: boikoartem
Old posts and spam for breakfast! Mmmmm…..
Rob
Forma Design Contest
