Revit & Autocad
Revit & Autocad
nikpearce
Message 1 of 32
Revit & Autocad
nikpearce
Hi folks new user looking for some expert help. Just before Christmas I had a chat with an architect about learning to do CAD, I was given a brief to learn AC and send some samples over. Well as I’m currently doing an engineering degree, I get access to everything.
so I started using Revit instead and absolutely love it, basically the architecture company doesn’t use Revit and I don’t want to go back to AC.
Will it be possible for me to do my work in one and it will be compatible their end. Thanks in advance.
Replies (31)
Message 21 of 32
HVAC-Novice
@Ric_Weber wrote:
@HVAC-Novice you stated, "Revit also isn't a good tool to design a consumer product, like a car."  I would agree, consumer products; cars, appliances, tools, etc. would best be designed in the realm of Inventor, 3ds Max, Fusion.  Those products that are part of the Product Design & Manufacturing Collection.
You also said, "I don't know about the feasibility of incorporating Civil and Plant features in Revit." and you're right in regards to the Civil definitely.  That is why I was talking about InfraWorks being a possible option there.  Not knowing all of the capabilities of InfraWorks and Civil3D, I am unsure, but I would believe there would be enough overlap to combine the functionality into one application.  An application that could seamlessly integrate with Revit.
Plant features, in my experience is basically, mechanical, electrical, and plumbing items (machines, electricity distribution, and pipes and valves and regulators).  So other than being larger, what would the difference be between that and MEP modeling.  The information would just be different that is plugged into the items modeled.   I could say that I could see a day when the MEP/Plant functionality within Revit could become a separate extension that users could choose to install or not install.  That could take us back to the days when Revit Architecture, Revit Structural, and Revit MEP were separate applications.  Not a bad option as long as they continue to work seamlessly together.
Your statement, "My first question would be, who pays for the added cost if most current Revit users only design building features?" confuses me a bit.  Don't most engineering and architectural firms already subscribe to the AEC Collection for their users?  All of these applications are already available in that collection.  Therefore we are already paying for them.  By consolidating the applications we would essentially also be applying all of that manpower into one application instead of across several.  Therefore the cost to Autodesk would not increase and update production could theoretically increase.  Which is kind of an answer to your comment of "Especially with Autodesk already way behind with fixing and providing the Building design features in Revit." with which I definitely agree.  In my "roadmap", if you will, Autodesk would have a lot fewer products, but equal if not higher capabilities.  Focus would be narrowed.
These are just my opinions.  I doubt if Autodesk or anyone of any influence would ever listen to me, but this is how I think.
I didn't see "Plant" among all the software in our AEC package. But I saw it includes Civil 3D.
I'm not civil engineer, but Civil design includes the overall system (i.e. the entire sewage system of an entire City, and not just the one project).  This is very unlike a building design where we really are independent off any other buildings or streets outside the project.
Each of the software they have is a spaghetti-code from different companies Autodesk purchased. So it isn't easy to just combine them. I don't know if "Plant" has any MEP features that are better than Revit. but I doubt they will easily port to Revit.
I think they would have to start with an all new software that includes options for Buildings, Civil, and Plants. Probably a web-based application. That would solve many problems including versions. Probably can be done. But I doubt Autodesk is the company to do it. Seeing the slow disaster ACC is, I doubt they want or can do it.
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
Message 22 of 32
Ric_Weber
@RDAOU   I agree.  Something has to happen somehow.  I have heard that about the code that Revit is built on as well.  That's why I'm wondering about the future of the application being online?  Just my thoughts though.
I was schooled in Cobol, Pascal, and Fortran back in the 80's, so I know exactly what you're talking about.  I would be willing to bet a lot of younger coders today wouldn't even have a clue what we're talking about though!
Ric Weber
If this post helps you, please like it or mark it as your solution. Thank you.
My Ideas: https://forums.autodesk.com/t5/forums/recentpostspage/post-type/thread/interaction-style/idea/user-id/12292525
Message 23 of 32
nikpearce
I’ve only just started to learn. I don’t need them changing to a new one just yet.
Message 24 of 32
nikpearce
It seems to be the way these days, everyone is pushing for the cloud.
Message 25 of 32
Ric_Weber
@HVAC-Novice, if you have the AEC Collection you should have "AutoCAD Plant 3D".
Regarding functionality of Plant being "ported" to Revit, I agree.  I'm just saying the functionality.  It would be completely different code from what is in Plant.  As you said these are things that were acquired from different sources, so an easy merging of code, no.  They would have to recreate the functionality of Plant, for instance, into Revit.  I feel like a lot of the basic functionality would already be there due to the piping and plumbing capabilities.  But not knowing for sure, I may just be totally over simplifying it.
I agree that probably the best way to move forward would be to move towards web-based applications.  Will that happen some day?  Who knows.  But if they want to give us those tools that we are asking for (just look at all of the different ideas for all of the different applications out there) I think Autodesk will need to make some big move like this in the not too distant future.
Ric Weber
Message 26 of 32
mhiserZFHXS
@RSomppi wrote:
@RDAOU wrote:
They haven't given up on it, but its code is outdated. Users see new features being added, but the core code has either reached or is nearing the end of its lifecycle. There are no major changes or developments to its algorithm. It’s already a 28-year-old software with little room for further enhancement. Any new feature they introduce won’t be a significant breakthrough due to the limitations of the existing code. It’s like saying, “I’m still going to be using COBOL, PASCAL, or FORTRAN" in 2040....if you say that today people will tell you WTF!!
The same can be said for AutoCAD but it is still around and relevant.
I think the overall simplicity of AutoCAD is why it is still around and why it probably will be for awhile. It has a pretty shallow learning curve and there aren't really any big changes that can be made for it at this point.
Revit opened the door to BIM on a large scale. But there are clear things that COULD be updated or added to it that haven't been yet. Maybe its not possible. Maybe its too hard and not worth the investment from Autodesk. But some new program will come around someday that will do those things. Will it be next year? No. In 5 years? Probably not. But 10? Maybe.
Its like comparing a book to an E-reader. A book is a book. It does what its been doing for years and it does it well. Why change? But an E-reader, while doing the same general thing, has loads of room for improvements. It started with more storage. Then internet connectivity. Then then the ability to have an audio-book synced. The concept of an E-reader will continue to change and improve, and old ones will become obsolete. The potential is there, so it must be built upon. Same with BIM.
Message 27 of 32
RDAOU
Not really. Yes, AutoCAD has been around for twice as long as Revit. The first release of AutoCAD (1.0) was in 1982, and its initial version was built using SPL, Autodesk’s proprietary "Scene Processing Language." In 1984, Autodesk transitioned to C, literally rewriting the entire software. Over time, they did it again, primarily recoding AutoCAD in C++, incorporating .NET, AutoLISP, and ObjectARX (C++ API) components...One can see the pattern and progress there. In Revit, Not.
Irrespective of all that, the comparison between Revit and AutoCAD is about as valid as saying that installing a go-kart with a 2-stroke engine is the same as powering a massive cargo ship with the same 2 stroke engine — technically, they both should run but the question is more about the adequacy and efficiency. One may still run the Go-kart on that engine for an additional 20 years while the competition is go-kart vs go-kart but one cannot rung that cargo ship on a 2 stroke engine when today's standards require that it goes nuclear (figuratively speaking of course)
Message 28 of 32
Renee_Ve
You answer about architects not using Autocad is right, but mostly for new buildings.
In building maintenance and renovation, Autocad is still in use, because of having a base of old drawings, and not having the drawing capacity to set up revit models for this
Message 29 of 32
mhiserZFHXS
Depends on what kind of work you're doing on existing drawings. If its just record drawings or small things like a roof replacement, sure. But more extensive renovation? Model it in BIM.
Message 30 of 32
Renee_Ve
Of course BIM is better in every way,
But my company is already in transition for over 10 years to start use BIM on renovation also, but it has not happened yet.
Only renovation for BIM buildings yes, but that does not happen very often yet.
I am still waiting to receive my first REVIT project, I do have license, of course.
Problem is we have no real drawing capacity or departement anymore,
most is done by  external companies and I have to manage those.
Message 31 of 32
nikpearce
Revit feels like I have found a tool which will make my future work life happy.
Message 32 of 32
Ric_Weber
... and then sad, and then happy again, and then frustrated and then happy again, and then confused.
Ric Weber
