Saving a Template from an Engineer as a project.
timXXAW4
timXXAW4
The reason I got into Revit was to provide services to a couple family members who are engineers and designers.
I received from one of them "General Structural Template.rte" He wants just wants me to give him a 3D model to work. I did have to turn on Architectural discipline in order to draw and see my drawing. I've drawn the foundation walls and have gone to save the project. "File>save as>project" is greyed out. How do I save it as a file in my computer so I can give him what he wants and send it back to him?
RDAOU
@timXXAW4
You do not model straght in the Template.
  • Place the template as you have received it in some folder
  • Open Revit
  • File >> New >> in the Dialoge that pops up hit BROWSE
  • navigate to the folder where you placed the template and select it
  • then click ok
That will be the project (.rvt) which you will work in
NB: You do not want to return that .RTE to your family/relative with stuff modeled inside it...he wont give you any new jobs 🙂
RSomppi
The template is for starting a project. You need to initiate a new project file, .rvt, by using the template file, .rte. The .rte cannot be saved as a .rvt. It is a container file for your settings and preloaded content.
The fact that you were sent a structural template makes me think you are doing a structural model and should probably be using the structural discipline. Using architectural could be a mistake but I don't know the requirements of the project.
Before embarking on your journey, I'd suggest you take a course or two on the essentials of Revit. Having this core knowledge will help you tremendously with these seemingly minor issues that could cause major headaches if handled inappropriately.
timXXAW4
Thank you. That was the ticket.
timXXAW4
Thanks for the input.  Just for the record, I've been taking courses from 3 different online videos and training for more than 200 hrs. This particular situation hadn't come up yet. I continue to go through the courses.
