Revit 25 problem_Project browser + Home
oskarhar-97
oskarhar-97
Hi!
The Home page in Revit where I open recent projects is without text and images. The project browser too is without text or images, so I can't open/see multiple views. This happens in all projects I open. I've tried to uninstall Revit and plugins (chaos vray etc) and reinstall several times. Same issue occurs every time. What can I do?
Simon_Weel
What if you rename the user folder to something like 'old':
C:\Users\<username>\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2025.old
This will force Revit to recreate the profile which could solve the problem.
handjonathan
Hi @oskarhar-97
Thanks a lot for posting your question to the forums!   Has the solution suggested by @Simon_Weel helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
oskarhar-97
Thanks for the advice @Simon_Weel ! Worked on a different computer for some time and when I tried again now on the problematic one, it was back to normal..
Will keep the advice up my sleeve in case it reappears!
Also, thanks for following up @handjonathan
CarlaG_AU
I have the same issue. I tried Simon's solution but it didn't work... what I have found that works is opening a second copy of Revit 2025 - the second one works fine, and I can close the first problematic one.
