Revit 24 - Toposolid - How to unite a region of topography that was previously separated from the rest of the surrounding topography?
lu_cas_alves
Message 1 of 13
lu_cas_alves
How to unite a region of topography that was previously separated from the rest of the surrounding topography? I separated an area of the land where the architectural project will be carried out from the rest of the topography, so that when I change the contours of my terrain, the contours outside the terrain would not change. I happen to want to modify the region of my terrain, and the problem is that I can't merge the region that was previously separated with the rest of the existing topography of the surroundings (I reasoned that I need to merge two regions so that I can redraw the area that will be separated again ). Can someone help me?
Replies (12)
Message 2 of 13
MichaelDol
This is the big disadvantage of the new tool, the detached part is now impossible to attach.
Mikhail Dolgikh / Михаил Долгих
BIM-Manager & Teacher / БИМ-Менеджер - Учитель
Facebook
Message 3 of 13
lu_cas_alves
That is an absurd, I wrongly designed the land on which an architectural project will be made and I would need to adjust it, are you telling me that I will have to create a project from scratch again just to fix this?
Message 4 of 13
l26583
Community Visitor
Community Visitor
It appears that this happens only when you use a spline to slice.
Message 5 of 13
architects4
Hi, I have this issue as I measure the topography of a site from several stations which results in seperate datasets these then need to be combined. I used to manage this easily with the old merge topography tool.
My current workaround is rather clunky but does work! I have the following workflow (which will also work to rejoin split toposolids)
  • Create the seperate toposolids in Revit and get them aligned relative to each other
  • Export to stl format
  • Load into Blender
  • remove all of the surfaces except for the top surface
  • Export the points to a text file (using an excelent macro for Blender that I found with a web search)
  • Create a new toposolid from CSV in Revit
Voila, only takes a mere few hours!
You can also fill in holes and gaps in a toposurfce like this and add pints in the CSV file to extend the new surface
It's a bit of a pain but quite flexible once you are familiar.
I guess someone with a full version of Revit could write a macro to export the points directly but I only have Revit LT (my turnover is too small to justify the full version which is a shame)
Message 6 of 13
Haider_of_Sweden
Hello @lu_cas_alves and @architects4
I got a solution that is a bit better, but still not the optimal solution that we all are looking for.
  • Isolate the topography surfaces you want to merge.
  • Export the scene to DWG - Both Solids or Mesh works
  • Link the DWG back into Revit
  • Now create a Toposolid from Import and pick the DWG you just imported.
  • You can now erase the old ones
Please do vote on this post regarding merging toposolids. I am surprised that at the time I am writing this, only 15 votes, including mine, are to be seen.
https://forums.autodesk.com/t5/revit-ideas/merge-toposolids/idi-p/12225905
Message 7 of 13
architects4
Hi Haider,
This is an interesting solution.
I will definitely try this. It sounds much simpler than my method using Blender!
Peter
Message 8 of 13
handjonathan
Hi @architects4
Thanks a lot for posting your question to the forums!   I hope the suggestion by @Haider_of_Sweden works for you. Please let us know if successful.
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
Message 9 of 13
bengalik
Haider_of_Sweden,
When I create the Toposolid from the Imported DWG,  all of the points have a z value of 0 - the new Toposolid is flat.
Any idea what I'm doing wrong?
Message 10 of 13
luizfelipecesario
Observer
Observer
I used to do topography work in just a few minutes with the ground points. I could align with the walls, wouldn't accidentally move the terrain because instead of moving the point, I move the terrain... I could SEE the points I wanted to align with a reference plane... All this in exchange for a "better representation" and digging holes under the ground. Things that I bet not even 5% of users need... Congratulations, they messed up one of Revit's most powerful tools.
Message 11 of 13
giorgioMZL6L
@handjonathan Can someone at Autodesk address this issue?
RE: Inability to merge topo solids after they have been split?!? This is a huge oversight. Its the only way to work with topography effectively on slightly larger sites/ more complex sites with more points. Not to mention anything bigger!!!
Secondly, the fact that subdivisions cant exist with a +0.000 elevation is also insane to me. I have seen some forums asking for there to be an ability to go negative in elevation as well which i think is a great idea.
This should definitely be a hotfix at this point. 2 years of no improvement is crazy.
Message 12 of 13
geovanna_martins6R43N
Olá @Haider_da_Suécia! Obrigada pela sugestão! Tentei fazer esse passo a passo por aqui, mas não consegui. Você poderia gravar um vídeo mostrando essas etapas? Acredito que eu tenha feito algo errado.
Message 13 of 13
cpayneXMMPL
this solution worked for me, thx haider. still something that autodesk should work to resolve.
