REVIT 2026 Won't export to IFC?
katsanosengineer
Message 1 of 9
katsanosengineer
Hello, lately I've been having some issues exporting a project to IFC format. I have both versions 2026 and 2024 downloaded, and have recently switched to 2026. When I exported IFC's from the 2024 version, I had 0 problems doing so, but now, the latest version is giving me issues. It shows this message, (image)
I have no idea what the message might refer to, and since I cannot save the project in an earlier version like you can do in AutoCAD, I'm completely at a loss.
What can I do?
Replies (8)
Message 2 of 9
nadiaVXVWZ
Community Visitor
Community Visitor
I have the same problem.. anyone knows the response for that?
Message 3 of 9
FG_RVT
Looks like a Windows issue no? Like you try to overwrite the file filename.ifc but that file already exists and you don't have write permissions for that file / directory. I'd try to save to a different directory.
Message 4 of 9
mari.shimode
Hi @katsanosengineer, how are you doing? Please reply if you still need assistance. If you have solved the issue, please click the Accept Solution button on a reply you have found useful so that others who have the same question can find the information easily. Thank you.
Mari Shimode
Message 5 of 9
eddieDJL7E
I am also having this issue. Cant get it to work at all.  All permissions etc are fine.
EDIT: I tried saving the IFC to the desktop and that worked. I was originally trying to save to a mapped network drive and that was failing with the above error. I know the permissions are correct in windows as i am able to open and edit all files within the folder i was trying to export the ifc to.
Message 6 of 9
MiWolff
Does your Export IFC window show a version number somewhere. If it does not, your exporter is the out of the box one. Try updating it to the latest version.
Message 7 of 9
thiruvengadam.vijayaraghavan
Hello @katsanosengineer, if you are saving on a network drive, could you please check if you can save IFC files to the local drive, for example, to C:\Autodesk?
Message 8 of 9
geraldDUN6M
Community Visitor
Community Visitor
Yes, it works for me as well, save in the desktop. thanks for this one.
Message 9 of 9
mari.shimode
Hi @katsanosengineer, I have marked replies from @eddieDJL7E and @thiruvengadam.vijayaraghavan as an accepted solution so others who have the same issue can find the information easily. Thank you for visiting the Autodesk Community.
Mari Shimode
