Hi @HVAC-Novice
Revit Version
My display and video drivers are up to date. I updated the Revit to R2026.2.
Scaling settings
See my monitor scale settings in this snapshot.
Setting the scale to 100% makes text unreadable. Clearly too high for the monitor I use, so 150% works fine.
Compatibility settings
See my compatitbility setings in the snapshot as well.
Project browser and Properties
- When I open Revit on my laptop screen everything is ok, and scaling is perfect; all text is clear and works very well. Once I drage the Revit window to the 4K monitor screen, the properties window scales properly, but on the other hand the project browser doesn't scale well.
- If I terminate the Revit window on the 4K monitor, then launch it again, I now get black margin around the properties and the project browser, but when I drag it back to the laptop screen close the window, then launch it; I have to drag it to the 4K monitor then scenario (1 above) occurs.
NB: My work around to the black margin has been to always launch Revit on my laptop and drag the window to the monitor once I've opened a project (even thought the project browser doesn't scale well as compared to the properties) and draging back to the PC screen before exiting Revit (just so that it lauches on my PC screen), then repeating this whenever I want to use Revit. Pretty annoying but it's a work around. Revit 2022 used to work fine, setting "high DPI scaling override to application"
Hardware
Mylaptop is Lenovo P14s and my monitor is Lenovo P32-p20
I hope this information will better explain the situation I'm faced with right now. Will appreciate your help on this. Thanks.
