Revit 2026.0.1's 'Attached Detail Group' tool's working command loose ability to be assigned shortcut key
What I found for Revit 2026.0.1 is that there is a missing CommandID shortcut for 'Attached Detail Group', whilst 'Attach Detail Group' is working fine as previous version e.g. Revit 2025 & prior.
For this workflow there are original 2x commandIDs that go with it, as below:
CommandName: CommandID:
Attach Detail Group ID_EDITGROUP_ATTACH_TO_GROUP
Attached Detail Groups Dialog_ElementGroup_EditGroupNew:Control_ElementGroup_EditGroupAttachDetail
Despite 'Attached Detail Groups' is still working in Revit 2026 BUT shortcut key CAN'T be assigned to it because its commandID is MISSING.
Both tools need to be working hand-in-hand, and if 'Attached Detail Group' can't be assigned a shortcut key the workflow could be handicapped and inefficient for projects that make use of attached detail groups, eg multi-storey apartments etc.
I am suspecting that the developer might have left out the commandID or accidentally deleted it.
May Autodesk look into this and bring back the commandID for 'Attached Detail Group' tool, so that a shortcut key can be assigned to the tool ?
Not sure if it is something wrong with the Revit 2026.0.1 that I used...but anyone else could give it some tests to find out if similar issue persist...
P/S - another separate post addressing missing commandID for Group's "Converts the selected group to a linked file"
