Revit 2025 Site Excavate Tool Issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am working on using two toposolids (existing and new), and using a schedule to compare the cut/fill between the two. The "existing" toposolid is a flat toposolid at the finished floor elevation of level 1 which is mimicking a flat building pad provided by the owner before the GC gets on site.
In order to create the New toposolid surface, I am using the excavate tool and excavating the floors which contain a lot of sloping for drainage (first floor of a parking garage) from the new toposolid (I used model in place component voids for a few cleanup spots, but not having issues with that). This seems to work 90% of the time, but I am having a very strange occurrence when excavating this one specific floor. You can see in this image, the cut shows 2247CY of cut, and as soon as I excavate the main floor it seems to error out and the cut goes to 0 (I tried adding additional cuts elsewhere and it refuses to change from 0 at this point, so it is not like there is actually 0 cut here, the vault in the middle is 100% cutting into the existing topo)
The only thing I can get to make numbers populate again is by raising or lowering the main floor a few inches.
I am fairly certain this is a bug in R25, but wondering if anyone has any ideas for workarounds/alternate workflows for this?
