I've never done much with plantings in the past but am trying to improve the look of my exterior elevations.
Wondering why, when trees are placed, they block some elements but not others. I have trees in the front yard that block out windows but the rest of the geometry of the building shows over the trees.
Guess I need a little help.
Thank You
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
Sounds like you are describing the difference Non-Cuttable and Cuttable Families.
RE: Non-Cuttable Families:
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-00DC7EDC-996D-4BA0-8263-58E8B1771078
RE: Cuttable Families:
https://help.autodesk.com/view/RVT/2025/ENU/?guid=GUID-3253EFCA-F38F-4086-9A4D-C873D8D04867
You can Recategorize a Family if you want different cutting behavior from it.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-68EFCA67-4913-4E00-AB9E-F2E6A7BEF8C6
