Revit 2025 - Rotating on 3D view turn the project into a blank page
thici_r_f
thici_r_f
Community Visitor
Community Visitor
When I rotate my project the page turns blank, same happens when I open a floor plan I can't see my construction, I have to close Revit and open again so it shows the project, sometimes it take 5 times closing and openning again to show. Is it a memory problem? My pc has 32gb RAM memory, my GPU is NVIDIA P1000 so it's compatible and it is uptaded. Please how can I solve that?
vitorbortoncello
maybe change the center of rotation (shift+w)
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
azad.Nanva
if you select a element your pivot point for rotate in the view is update to element and this remains to select the new element.
check this like the attached film ,and if still blank use the Zoom To Fit or dblclick middle mouse button.
azad.Nanva
and for GPU , check the Hardware in Revit :
and P1000 is not so good one really .here you can see the GPU and rank of GPU:
https://gpu.userbenchmark.com/Compare/Nvidia-RTX-3050-vs-Nvidia-Quadro-P1000/4127vsm271840
handjonathan
Hi @thici_r_f
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @vitorbortoncello @azad.Nanva  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
