How to create a curved stair section
akoumtch
akoumtch
Hello All,
I am trying to make a continuous stair section, but in our case, the stair has a curve at the landing. Can anyone help with a work around?
vitorbortoncello
you can't draw a curved segment of the section, you have to split it multiple times to achieve something similar
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
handjonathan
Hi @akoumtch
Thanks a lot for posting your question to the forums!   Has the solution suggested by @vitorbortoncello helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
akoumtch
I don't think this was the right solution, because the split is helpful tool, but you cannot split and rotate a portion of the view. I was able to get the view I need by stitching together multiple sections and hiding the callouts in plan.
