revit 2025 graphics tab in material browser not working
dankofre
Message 1 of 75
dankofre
I recently updated Revit to 2025 from 2024. . Now, I can no longer modify any typical graphic settings, i.e., cut and surface patterns, for any materials. When I access the Materials Browser and select any materials graphics tab, it flickers briefly, showing a duplicate of the appearance tab, and goes blank.
Replies (74)
Message 41 of 75
ha5529P
Same issue. Absolutely mind blowing that Autodesk has not fixed this yet.
Message 42 of 75
Tlarkin
Same issue. Revit 2025.4 (Windows 10) (Note: I noticed this after uninstalling Revit 2024)
Message 43 of 75
Thanos603
A Revit Material Repair Utility is now available to restore the material files that were incorrectly removed by the Revit uninstall.  Additional information regarding this utility can be found in the Revit release notes, https://help.autodesk.com/view/RVT/2025/ENU/?guid=RevitReleaseNotes_2025updates_html.
Anthony Michniewicz
Principal QA Analyst
Message 44 of 75
hvcprecast
waitig for a work around solution instead of reinstalling Revit..
John
Message 45 of 75
andresotalvaro12
Community Visitor
Community Visitor
I did the same and it worked. Unistall and install
Message 46 of 75
Mark_Engwirda
This still happens in Revit 2026!
I have revit 2026.1 and there is no option to reinstall or repair the current install it.
My understanding is that this occurs when you delete a previous version of Revit, regardless of which version it will cause this problem.
The identity and appearance tabs still work
My take is;
#1 This should never happen
#2 Where is the fix without having to remove the current ver of Revit and reinstall from scratch?
#3 Where is the solution for Revit 2026.?
Message 47 of 75
Mark_Engwirda
Luckily the 2025 the MaterialsRepairUtility.exe also solves the issue on the 2026 ver but really this shouldn't happen.
Message 48 of 75
mhiserZFHXS
Yup. Just happened to me on R26 as well.
Message 49 of 75
mhiserZFHXS
Is that MaterialsRepairUtility.exe really just supposed to open a command window? I've downloaded and run it twice and that's all that happens.
Message 50 of 75
Mark_Engwirda
@mhiserZFHXS I ran mine in Admin mode and of course restarted Revit
Message 51 of 75
mhiserZFHXS
I did all of that as well, but again, the .exe just opened a command window when it was done. And there was no change in Revit.
I just wound up uninstalling and reinstalling Revit. Not exactly a great use of time, but I couldn't wait around for an answer.
Message 52 of 75
tailosimpson
Observer
Observer
Having the same issue.  First updated to latest version of 2025.4 and it didn't fix the issue.  ChatGPT suggested that reinstalling Revit 2024 solves the issue with the Revit 2025 graphics tab showing BLANK... Trying that...
Message 53 of 75
tailosimpson
Observer
Observer
Reinstalling Revit 2024 fixes the issue.  Uninstalling Revit 2024 after installing Revit 2025 causes this issue.
Message 54 of 75
Mark_Engwirda
@tailosimpson that's correct, try the repair utility first as it's a much simpler fix.   https://up1.autodesk.com/RVT/2026/MaterialsRepairUtility.exe
Message 55 of 75
anjaholtzhausen
I  have the same problem in Version 2026
Message 56 of 75
MoShakeri
Community Visitor
Community Visitor
I’m having the same issue. While the graphics are accessible to my coworkers, they’re not showing up on my system. We’re all using the same Revit version — 2026! It’s so strange!
Message 57 of 75
MoShakeri
Community Visitor
Community Visitor
I’m having the same issue. While the graphics are accessible to my coworkers, they’re not showing up on my system. We’re all using the same Revit version — 2026! It’s so strange! Oh, I can not post a reply either!
Message 58 of 75
banu_arikan
Community Visitor
Community Visitor
Thank you so much. It solved
Message 59 of 75
akshay_surveKTDLP
Hi @dankofre,
Thank you for reaching out on Autodesk Forum.
I would want to share this information which is shared in help page: https://help.autodesk.com/view/RVT/2025/ENU/?guid=RevitReleaseNotes_2025updates_html
Uninstalling Revit 2024 after Revit 2025 is installed, may cause a blank Graphics tab in the Material Browser within Revit 2025. This is caused by the Revit 2024 uninstall process removing shared material files. To restore the material files, please run the Revit Material Repair Utility.
Note: Once the utility starts, there is an initial file unpacking process, which may take approximately 20 seconds before the interface shows progress.
This unusual behavior in Revit 2026 is resolved, more information can be found in this Autodesk knowledge article: Graphics tab missing in Material Browser in Revit
Akshay Surve
Autodesk | Technical Support Specialist
Message 60 of 75
Mark_Engwirda
@akshay_surveKTDLP unfortunately this is not the case as it still occurs in Revit 2026.
Maybe we will get lucky with Revit 2027 but we will have to wait and see 🙂
