Revit 2024: Why the underneath floor does not appear in a gray color from the upper floor?
JamaL9722060
JamaL9722060
Foe example, in the screenshot below, the sketch of the 1st floor appears in grey color from the 2nd floor. However, as the 1st floor is copied to the 2nd floor, this second floor doesn’t appear in gray color from the 3rd floor
What could be the issue here?
Jamal Numan
RobDraw
There are many possibilities. I'd start with different view settings.
Rob
syman2000
I check the setting. Apparently your Level 3 underlay is set to none. If you want to display as grey, you have to set this to level 2.
JamaL9722060
Right. It works fine
Jamal Numan
