break line gone in 2024
mowerc672
mowerc672
Community Visitor
Community Visitor
There are no break lines in Revit 2024, can someone help? Also, repeating detail components not working. These newer versions, 32-24, are not like 2022 and all tutorials aren't up to date so this is frustrating. Thanks for any help CM
syman2000
Under insert>Load Autodesk Family and search for Break line. It should show up. As for repeating detail component, are you attempt to create a custom component or simply you cannot find the content?
handjonathan
Hi @mowerc672
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @syman2000 @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
