Revit 2024: Why the underneath floor does not appear in a gray color from the upper floor?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
JamaL9722060
293 Aufrufe, 3 Antworten
Foe example, in the screenshot below, the sketch of the 1st floor appears in grey color from the 2nd floor. However, as the 1st floor is copied to the 2nd floor, this second floor doesn’t appear in gray color from the 3rd floor
What could be the issue here?
Jamal Numan
3 ANTWORTEN 3
Nachricht 2 von 4
RobDraw
als Antwort auf: JamaL9722060
There are many possibilities. I'd start with different view settings.
Rob
Nachricht 3 von 4
syman2000
I check the setting. Apparently your Level 3 underlay is set to none. If you want to display as grey, you have to set this to level 2.
Nachricht 4 von 4
JamaL9722060
als Antwort auf: syman2000
Right. It works fine
Jamal Numan
