Revit 2024: The “automatic ceiling” tool fails to sketch the ceiling,
JamaL9722060
JamaL9722060
In the screenshot below, I couldn’t figure out why the automatic ceiling” tool fails to sketch the ceiling
What could be the issue here?
Jamal Numan
Sean_Page
Try to make the Height Offset From Level a little less than the level height. You are currently placing the ceiling  above the walls and therefore it is t bound.
Sean Page, AIA, NCARB, LEED AP
Senionr Partner, Computational Designer, Architect
syman2000
Do you get a yellow warning sign? If so, the ceiling is higher than the cut plane and will not be visible in the plan view unless you change the view range.
JamaL9722060
Thank you for the help. I got it
Jamal Numan
