Connection between a steel beam and a reinforced concrete slanted column
e12013443
e12013443
Hello! Can You tell me how i can use the Revit Connections to connect a steel beam and a reinforced concrete slanted column? I Created the Column from Massing and declared it in the settings as a column.
Alfredo_Medina
Hello, most likely you need steel plates with shear studs, embedded in the concrete column, on each side of the column.
