Hi - i am having an issue when i am working on 2 files (for example a family within a project) and the project browser seems to stall and I cannot click on anything.
The only solution I can see is turn on and off again but as this is happening multiple times a day.
Any ideas??
Any ideas??
I have seen issues like this when the PB or Properties are not docked inside of Revit, or Revit isn't on the main monitor. If either of those are your case try working with Revit on the Main monitor with the pallets docked, see if that resolves the issue.
Thank you will give this a try and see!
I often have to reset the .dat file switching between office and home setups which seems to confuse Revit at times.
Help | Troubleshooting: Project Browser Display | Autodesk
