revit 2024 - not loading after failed update
4 REPLIES 4
orges1996
327 Views, 4 Replies
So i tried to update revit 2024 through the autodesk access (revit 2024.2 Update) , firstly it stuck at 97 % and than my revit did not open anymore....since than i cant install, uninstall or do anything with REVIT 2024 ALL THE WORK I HAD GONE . I'm using the educator version cos i teach at university. Also when i try to update again it shows the thing that cant find the RVT.msi or something like that and i cant seem to make it work despite all the things i've tried ...and please do not suggest me again a clean install cos i've done all and the same problem also i cant afford to make a full system clean (to reinstall all the programs from the start from windows  cos i have a lot of important work in my pc.
ill add to my message 2 screen shots one from when i open revit (first) and one from when the update stucks (second)
1.
2.
@allmembers
@revit2024
Tags (1)
4 REPLIES 4
in reply to: orges1996
Yah, unfortunately this is happening quite a lot.  The solution is to do a clean uninstall and then reinstall Revit from the browser (via your autodesk.manage.com account).
How to Complete a Clean Uninstall of Revit products (autodesk.com)
Note: we didn't need to do step #7 (regedit).
DarrenP
Go through this: https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Revit-2024-2-Updat...
DarrenP
orges1996
in reply to: barthbradley
i did this and again the same thing happened but a friend of mine found a work around this but i didn't see how he did it i just left my laptop to him and i got it all fixed
orges1996
in reply to: DarrenP
nope this did not work
Forma Design Contest
Technology Administrators
