Revit 2023: Why the added level doesn’t get in line with other levels on the 3D?
JamaL9722060
Message 1 of 10
JamaL9722060
For example, in the screenshots below, as level 4 is added, it doesn’t get in line with other levels.
How this can be controlled?
Jamal Numan
Replies (9)
Message 2 of 10
RSomppi
Why not just copy an existing level with the extents as you like?
Message 3 of 10
You can copy the level instead place a new one.  Or, assign them to the same scope box.
Message 4 of 10
syman2000
Check this video how to control your grid and understand how it works. Your grid comes in 3d and 2d setting. The minute you drag the 3d element, the extent of the level changes globally. If you aren't careful, you will get mis-match level at your 3d view.
https://www.youtube.com/watch?v=OM0PTfGrp_0&ab_channel=PracticalBIMResources
Message 5 of 10
JamaL9722060
Copying the level doesn’t create new level as per the screenshots below. The created level remains dark but not blue
What could be the issue here?
Jamal Numan
Message 6 of 10
Add a new plan view associated to the new level and it will turn blue.
Message 7 of 10
JamaL9722060
I couldn’t figure out how to “add new plan view associated to the new level. How this can be performed?
Jamal Numan
Message 8 of 10
View > Plan Views > Floor Plan
Message 9 of 10
SteveKStafford
Create a new floor plan view, choose the new level from the list: View ribbon > Plan View > Floor Plan
Steve Stafford
Message 10 of 10
JamaL9722060
It works fine. Many thanks
Jamal Numan
